12-06-2025 01:40 PM
I recently understood that my current SIM card does not have to 5G. I mean wherever I go in London I can't reach a 5G connectivity. How can I change safely my card with EE to have it ?
12-06-2025 03:03 PM
EE SIMs are not "G" specific, they support all technologies form 2G > 5G. This applies to SIMs from 7 years ago just as much as it applies to ones from last week.
The difference is that older SIMs may not support 5G-Standalone, thus will always use 4G as an anchor coverage layer in addition to 5G. 5G-Standalone uses 5G-exclusively without using 4G, this can require a more recent SIM.
12-06-2025 01:53 PM
@MD106 is your device a 5G device? If it is is 5G enabled on it ? What device is it?
12-06-2025 01:57 PM
Yes my phone is a 5G device and it is enabled on it. It's a iPhone 16 pro.
12-06-2025 02:00 PM
@MD106 If you got the sim with the device it’ll support 5G even if that sim is around 3 years old it’ll support 5G.
12-06-2025 02:42 PM
Are on Pay As You Go or a Pay Monthly Contract?
12-06-2025 02:50 PM
I was on PAYG. But I called on 150 to set it up to Pay Monthly Contract.
12-06-2025 03:03 PM
