on 20-04-2024 10:22 AM
I forgot to text 150 and activate roaming. I’m now overseas… is there anything I can do?
Solved! Go to Solution.
on 20-04-2024 10:23 AM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
