Re: EE APN Settings: Where to find them
Alondonboy
I'm not particularly clued up on network connections but think what I'm trying to do should be pretty simple. I have an EE mini hub and am trying to use the chip from it in another minihub I've purchased. In the APN Configuration settings I've put the following:
Name - EE internet
APN - everywhere
User - eesecure
Password - secure
Auth - None (options - None/PAP-CHAP-CHAP/PAP)
Not getting any internet connection. Is something there wrong or is there any other information I need to input?
TIA
17 REPLIES 17
Alondonboy
Yes. As I've stated it works fine in the EE minihub but I'm trying to get it to work in the one I've purchased before I have to return it because:
1. To see if I can get a better signal.
2. Know my hub is prepared so once returned I can buy an EE data sim.
I don't want to be going through all this at a time I need to be using it when I could be preparing now with the one I have.
Leanne_T
Thanks @Alondonboy
These are the correct settings, does any other SIM card work in the new router?
Alondonboy
I don't have any other to try. My phone sim is O2 and apparently they don't work in a minihub. The whole purpose of trying to use the EE one is that  I know it works and would probably take up a contract with EE after so settings should be good to go.
Not being clued up on this doesn't help as not sure if these are the only settings I need to enter.
Leanne_T
Where did you purchase the new router? @Alondonboy
Is the router unlocked?
Alondonboy
Online. It's unlocked and supposed to work with almost all networks. I think it's more me doing something wrong as have no idea about setting it up
You shouldn't really need to set anything up. The APN would get auto set from the initial connection with the EE network.
Alondonboy
Something's not right then
Leanne_T
Morning @Alondonboy
I would suggest contacting the seller of the router if no connection i showing and the SIM is working in another device.
Thanks 🙂
