17-02-2024 08:33 PM
I'm not particularly clued up on network connections but think what I'm trying to do should be pretty simple. I have an EE mini hub and am trying to use the chip from it in another minihub I've purchased. In the APN Configuration settings I've put the following:
Name - EE internet
APN - everywhere
User - eesecure
Password - secure
Auth - None (options - None/PAP-CHAP-CHAP/PAP)
Not getting any internet connection. Is something there wrong or is there any other information I need to input?
TIA
17-02-2024 08:35 PM
@Alondonboy : Try Auth = PAP.
17-02-2024 08:41 PM
No change. Still not connecting.
17-02-2024 09:18 PM
@Alondonboy : Try the obvious combined setting.
17-02-2024 09:34 PM
Tried each option with a reset after and none are connecting to internet.
17-02-2024 10:02 PM - edited 17-02-2024 10:03 PM
@Alondonboy : What SIM do have in it?
17-02-2024 10:05 PM
EE Sim from EE minihub so I know it works
17-02-2024 10:13 PM
Contract or PAYG?
17-02-2024 10:31 PM
Neither really. It's prepaid for I believe 3 months to use whilst my main broadband is set up and running. It comes in an EE minihub and works sometimes but I have a poor signal where I am I have just purchased another make minihub to see if it picks up a better signal and also considering taking up a contract after for a data sim to use in it. The difficulty is connecting the working EE sim in the new hub to the internet. Phone connects to new minihub with sim in but something is wrong in the settings, stopping it connecting to the internet.
18-02-2024 07:41 AM
Hi @Alondonboy
Can you connect to the internet with the SIM card in any other device?
Doe a different SIM card connect to the internet in the new router?
Thanks 🙂
