16-04-2024 08:56 AM
I have a £10 pm payg plan but am in a position where I need unlimited data as well for a while. With considerable difficulty and phone calls to EE I managed to buy 30 days unlimited data add on for £40. This is current, but I will probably need to buy another 30 day add on. However there seems to be no option to just select and buy this using my ee account ei on iPhone or PC.
Unless it's a very simple transaction I find anything else is complex as the options seem endlessly layered or nested.
Help would be welcome.
16-04-2024 11:25 AM
Are you able to select the add-on on our add-on hub, when not connected to WiFi?
16-04-2024 03:34 PM
@Dingdongbell : Does it offer you the unlimited data add-on when you text ADD DATA to 150?
16-04-2024 05:49 PM
17-04-2024 08:22 AM
UNL DATA does it.
