21-03-2023 11:06 AM
I am paid up. I have 4.9GB alive. And I connect to wifi without a problem. But no connections away from wifi. the solutions I have looked at are all about SIM cards etc but that isn't my problem. It was fine till a couple of weeks ago.
21-03-2023 12:04 PM
The same has just happened to me, wifi only. There seems to be no way to check the network status.
21-03-2023 01:37 PM
Hi @bob1808
Does this happen in all areas or one postcode location?
Do you have a 5G/4G symbol in the top corner?
Jon
21-03-2023 04:02 PM
21-03-2023 04:11 PM
21-03-2023 05:04 PM
Hi @Teepee11,
Does the Network Status Checker report any problems in your area? (Please select the 'check status' option)
21-03-2023 05:28 PM
21-03-2023 05:37 PM
