16-08-2024 02:12 PM
I am having problems with mobile data when away from the house. I keep getting the message “could not activate mobile data network”. My mobile data is switched on and I have tried the recommended fixes like turning on and off. Please advise.
17-08-2024 10:46 AM
Hi Peter
At first it worked some of the time but the last few days I have not been able to use the mobile data at all when in a certain area away from the house. However, I had wondered whether the mobile signal has changed near me as it appears to be okay further away.
Yes I can see 4G/5G indicator.
Julie
17-08-2024 10:53 AM
Thanks @JulieTRose3
If this is working around some areas but not others, I'd definitely recommend having a check of our network status checker.
If you select the option to 'check service status' this will take a look at the area and see if there are any outages that could be having an impact on your current service.
Peter
17-08-2024 11:13 AM
Thanks Peter but I’ve tried this for my postcode and there are no problems in the area.
17-08-2024 11:31 AM - edited 17-08-2024 11:32 AM
Thanks for giving that a check, @JulieTRose3.
If this isn't flagging anything going on in your area at the moment, I'd definitely recommend reaching out to our technical support team, and they'll be able to do a bit more digging to see where this issue could lie.
Let us know how you get on 😊
Peter
