26-05-2021 12:53 PM
4g no longer working
reset network setting, restarted devise, checked content setting
26-12-2022 12:04 PM
No issues for my area,
iPhone XR
27-12-2022 08:17 AM
Thanks @Matthewlanders
If you log into your My EE app and select Menu then Settings, does use mobile data show active?
Leanne 🙂
27-12-2022 01:13 PM
Yes it is already active
28-12-2022 08:20 AM
OK, thanks @Matthewlanders.
Are you aware of any EE users in the same area as you with the same problem? Have you tried restarting your phone?
28-12-2022 01:12 PM
i am not aware of anyone else having the same problem in my area. I do travel a hour away from my home for work and it doesn’t work anywhere.
I have tried restarted it a couple of times but not difference.
Instagram is working and I do get limited data for things like WhatsApp. I have all the setting to allow data use but nothing is working as it should.
I was using this device with BT and had no problems.
28-12-2022 01:19 PM
Thanks @Matthewlanders.
I think it's going to be best for you to contact our technical support team so that they can look into this a bit further for you.
27-03-2023 05:35 PM
The same thing is happening to me, my 4G won’t show and I have a lot of data allowance left.
27-03-2023 06:31 PM
Hi @Afreen
Have you tried restarting your phone? It may also be worth checking the status of your network on our coverage & network status checker.
17-05-2024 09:02 PM
Christopher I too have the same issue as L22 and have followed all the same procedure's. I have even reset the network settings on the phone. Nothing has worked. I to was a BT customer and had no issues with this phone until a migrated across to EE. I have had this issue three times now. The other two were resolved by previously discussed guidance. This time however nothing is working.
What resolved L22 issue so I can resolve my exact same thing please?
18-05-2024 08:11 AM
Hi @LBWout
Thanks for coming here.
Have you tried the SIM card in another phone to see if you can connect to data?
