Mobile data not working
LL22
4g no longer working
reset network setting, restarted devise, checked content setting
27 REPLIES 27
@LL22  Have you looked at THIS as you can check the network on your area.    Also do you have any data left from your allowance.
Plenty of data allowance left
Not checked today but been going on a few days now and no issues when I checked the network before
James_B
Hi @LL22,
Are you only having issues in one location or everywhere?
Does your phone show it is connected to 4G in your status bar?
Can you make calls and send texts OK?
Having issues everywhere
phone showing as connected to 4g
calla and texts are ok
James_B
What happens when you try to load a web page over mobile data @LL22?
When loading a web page I get a message saying safari cannot open the page because your iPhone is not connected to the internet or safari could not open the page because the server stopped responding
Hi @LL22
Thanks for that information it really helps.
Could you please try the below steps for me, and let me know if it helps?
1. Turn airplane mode on and off again
2. Restart your device
3. Check you have the latest software
I have tried all and did not help
Jon_K
Former EE Employee
Thanks @LL22.
Are you able to try your SIM card in another phone?
This would help us to determine if the problem is following your phone, or your SIM card.
Jon
