MOBILE DATA ERROR
MARKOROLLO1
PAYG PHONE, IPHONE 5S, VERSION 12.5.7  SHOWING NO SERVICE, CANT MAKE OR RECEIVE CALLS OR EVEN TEXTXAND GET THIS ERROR MESSAGE
mobile data upload failed, your iphone cannot make and receive calls or access mobile data until it has been updated
WON.T UPDATE FROM 12.5, JUST SAYS ITS UP TO DATE.
I THINK ITS TIME FOR A NEW PHONE BUT WONDERED IF ANYONE HAD A SOLUTION?
AND I KNOW I'M TYPING IN CAPITALS 😄
Alex_H
Hi @MARKOROLLO1,
Welcome to the EE Community
IOS 12.5.7 is the last version supported for that phone so no further updates will be possible. If you have not already it would be worth resetting the network settings and restarting the phone to see if that resolves the error.
Resetting the network settings does remove saved Wi-Fi so make sure you have your Wi-Fi password handy to reconnect.
If you go to Settings> General> About is there any prompt for a carrier settings update?
Alex
6 REPLIES 6
Alex_H
Hi @MARKOROLLO1,
Alex
ee_user14
Openly admittiing that you're being intentionally rude on a public forum then.
How to make friends and encourage others to help you....
Thanks for replying, as i wasnt expecting one 😄
i dont have the phone with me at the moment, i'll try it when i have it 🙂
No, i was just typing in capitals as it was on caps lock for a form i was previously filling in which i always do in capitals to make things clearer., i hadnt noticed at first that it was still on so just carried on typing, no rudeness intended.
are you one of those that needs to see bad in everything?
ee_user14
Not really, but perhaps you don't realise - posting in capitals on the web is commonly taken as shouting, so rude.
It's fixed by toggling your caps lock key - one of your paragraphs was on all lower-case, so you just need to do the same.
tried reset network settings.
It worked 😄
not sure why that would happen though?, i'm not very techy.....
thanks again.
