I want more megabytes
Ivan34
 I bought a SIM card and now I have 8 GB of data, how can I change my tariff plan to more GB?
6 REPLIES 6
Are you on contract or PAYG?
I would guess you are PAYG with a £10 pack. If so, top-up enough before your current pack expires. Then text ALL PACKS to 150 & buy the bigger 1 you want. It will start when your current pack expires, replacing it.
thanks for the answer friend! I just bought a SIM card and it was 8GB, I want more! Then I’ll try to do as you wrote, send an SMS, I hope this helps!
Hello! How can I connect to unlimited internet?
Buy an unlimited data add-on.
please tell me where exactly to do this? Thank you
Text UNL DATA to 150.
