EE APN Settings: Where to find them
Sean_D
Former EE Community Manager
Hi there,
For APN settings please see our dedicated Help page at https://ee.co.uk/help/mobile/fix-problem/Managing-APN-settings.
This Help page will give you the link to download the correct APN settings for your device. It will also give you a step-by-step guide for the most modern devices.
Below is a list of EE APN settings for manual input if you need them.
iPhone
You cannot update/change APN settings on an iPhone as these are locked out by the network and are updated via carrier updates.
Android
The settings option may differ depending on the device you are using,
  1. Go to Settings.
  2. Go to More.
  3. Go to Mobile Networks.
  4. Go to Access Point Names (APN).
  5. Go to Menu.
At this point, you should insert a new APN for EE. Use the following.
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
Server: Not Required
MMSChttp://mms/
MMS proxy: 149.254.201.135
MMS port: 8080
MCC: 234
MNC: 30
Authentication type: Not Required or use the default value shown.
Then Save the settings. You'll then need to restart your phone. Please test if it has worked by trying to send an MMS.
Windows Phone
  1. Go to Settings.
  2. Go to Network and Wireless.
  3. Go to Mobile+Sim.
  4. Go to Sim Settings.
  5. Choose + add an Internet APN.
Fill in the following fields.
Profile name: EE Internet
APN: everywhere
Username: eesecure
Password: secure
Tick the box next to 'Use this APN for LTE' and tap Save.
  1. Choose + add an Internet APN
Profile name: EE MMS
APN: eezone
Username: eesecure
Password: secure
Proxy server: 149.254.201.135
Proxy Port: 8080
MMSC URL: http://mms/
Maximum MMS size: 1048576
Press Save and restart your phone.
Blackberry
  1. Go to Settings.
  2. Go to Network Connections.
  3. Go to Mobile Network.
  4. Choose APN.
  5. Select Mobile Plan Selector.
  6. Choose Contract or Prepay.
Fill in the following fields then press Save.
Access Point Name: everywhere
Username: eesecure
Password: secure
  1. Go to Settings.
  2. Go to Text Messages.
  3. Go to Advanced.
  4. Scroll past the SMS settings and find the APN Settings.
Fill in the following fields then Save and restart your phone.
APN Settings:
APN: eezone
Username: eesecure
Password: secure
MMSC Settings:
Proxy URL: 149.253.201.135:8080
Nokia
  1. Go to Menu.
  2. Go to Configuration.
  3. Go to Personal Settings.
  4. Choose Web.
  5. Press Account Name. Fill in EE Interent. Tap OK.
  6. Press Homepage. Fill in http://m.google.com. Tap OK.
  7. Press use pref.acc.pt then tap no.
  8. Press acc point sett > bearer settings.
  9. Choose pack. data acc. pt then type in everywhere and tap OK.
  10. Press username then type in eesecure and tap OK.
  11. Press password then type in secure and tap OK.
  12. Press the back button three times to go back to the network list.
  13. Press and hold the name EE Internet and then press activate.
  14. Press the back button.
  15. Choose def. config. sett and press personal config > default.
  16. Press the back button twice more and get back to the Home screen.
  17. Find and choose the menu option on the Home screen.
  18. Choose configuration.
  19. Choose personal settings.
  20. Choose options.
  21. Now choose add new.
  22. Choose multimedia msg. These settings will let you send picture messages.
  23. Choose account name, type in EE MMS, then choose OK.
  24. Choose server address, type in http://mms/ and choose OK.
  25. Choose use pref. acc. pt and Choose no.
  26. Choose acc point sett.
  27. Choose proxy, then Choose enable.
  28. Choose proxy address and type in 149.254.201.135, and choose OK.
  29. Choose proxy port, type in 8080 and choose OK.
  30. Choose bearer settings.
  31. Choose pack. data acc. pt, type in eezone and choose OK.
  32. Choose username, type in eesecure, and choose OK.
  33. Choose password, type in secure, and choose OK.
  34. Press the back button three times to return to the list of networks.
  35. Press and hold on to the network name, EE MMS, then choose activate.
  36. Choose the back button.
  37. Choose def. config. sett. and then choose personal config.
  38. Choose default.
  39. Press the back button twice, which will take you back to the Home screen.
Cheers
49 REPLIES 49
Katie_B
Hi @RH0803
Do you have another device?
It does not have to be an iPhone.
Are you able to follow the steps provided on this page to check the APN settings?
Speak soon,
Katie 🙂
OK we'll try.  We tried to use settings suggested by Vodaphone website and changing the domain to EE but my daughter's phone doesn't appear to have those setting options.  We'll try with my Samsung.  Thank you
Katie_B
Please be sure to keep us updated @RH0803.
Katie
I was holding out so much hope for this after having this problem for about a year but it hasn't worked 😞 Any other ideas? I need to access my work VPN from home and always did it by hot spotting off my phone signal (wifi non existing where we live) and one day it just stopped working. EE aren't helpful on the phone and work IT department are blaming EE, there must be a way around it!  Thank you in advance!
James_B
Hi @Lucy170,
Did your IT Team mention what they think is causing the problem?
Just that EE are now blocking VPNs and I should speak to them about removing all content blocking in my account. EE are saying its a problem with the way my connection is set up and I need to go back to them. The VPN works perfectly on o2, so EE are the problem!
Sent from Outlook for Android<>
Leanne_T
Hi @Lucy170
Thanks, we don't block VPN's if this is not working for you this would need to be reported to your IT department to be looked into in more detail.
Hi Leanne
The fact that my VPN works with an o2 mobile sim for an Internet connection would indicate it is an issue with EE. How would you explain that it works with that network and not yours? Happy for any help please? I have tried to limit the connection to IPv4 rather than IPv6 but this isn't working either. I really don't want to change networks other this but I need to be able to work from home in this way.
Thank you
Lucy
Leanne_T
Hi @Lucy170
I am not aware of any reason for this not to work for you.
Is anyone else on EE having the same problem?
There are a lot of forums about people having the same problem. I always used to use my phone as a mobile hot spot as the mobile signal is better here and one day it stopped working. I'm having the same problem with my 4g mobile router on EE. I can connect to my VPN when using WiFi, provided by EE, but one our phone lines are down at the moment and two we only get speeds up to 1mb where we live so it is very slow even when we are up and running. Is there anything else you can suggest?
