Data Plan
RubyD96
Hi, I’ve recently put my add on sim card into a different phone but the data plan has moved with it and when I check my account it tells me that the sim is still on a unlimited plan but on the phone it tells me it has 2GB of data it can use, can anyone help me sort this.
Matt_124
Some phones have an internal data counter/data warning built in that is set to 2GB as a default and doesn't have any way of knowing what's available on your plan.
If it is a Samsung device, you can go to Connection > Data Usage > Billing cycle and data warning, and change this yourself or remove the data warning entirely.
For other devices the steps should be similar, likely under Mobile Data settings.
Matt_124
Your data plan is on your SIM & thus will follow it anywhere.
That sorted it, thank you
Leanne_T
Thanks for coming back and letting us know @RubyD96
Have a lovely day 🙂
