problem
crown87
The device shown in the picture works normally during the day on the 4G system, and the connection is cut off at night. Restart the device, the connection is restored, and this problem is cut off only at night. What is the solution??
Katie_J
Hello @crown87.
Welcome to the community.
Do you have mobile devices with EE
If yes, do you experience the same signal issues on an evening?
Katie
Katie_J
Hello @crown87.
Katie
Yes, I have devices other than ee and there is no problem with it. The problem is only in the ee device
Christopher_G
OK, thanks @crown87
I recommend speaking to our Technical Support team so that they can look into this for you.
