ee router withdata
tony4122
how doyou change setting said password wrong its seriously hardwork nuts
Northerner
Hi @tony4122
Which router? (Colour)
Mobile routers have a password sticker or card. That message means you've entered the wrong password.
If you still have the original password reset the router via the reset button.
@tony4122 : Which router? They're all diff!
tony4122
4g wifi mini
tony4122
its the right password its on the card so to reset it is a waste of time thought i would try thisout not one of my better ideas
@tony4122 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
