Trouble seeing Data usage on Scancom SIM
Ddkdj45
I tried using http://add-on.ee.co.uk/   but it always shows
Please turn off your WiFi
To get access to this platform you need to turn off your Wi-Fi within settings.
And Wi-Fi is already off.  What should I do?
10 REPLIES 10
@Ddkdj45  What network does the device show it’s connected too.
Its connected to EE 5G
chistery
Could your device be using something like iCloud Private Relay, or a VPN?
Nope, all disabled!
chistery
I just tried it on my iPhone.
Turned off private relay, still can't get the add-on page in Safari, says turn off wifi, but it works on Chrome.
Still no luck
Then what's a "Scancom SIM"? As I read it they are somebody else's SIMs that piggy-back (MVNO) upon various other real mobile networks. In which case I don't see EE's http://add-on.ee.co.uk/ working from them. Indeed any data usage you have will be of Scancom's data not of EE's & so EE can't possibly know what your data usage is.
Get a real EE SIM & you'll be able to get to it.
They basically buy EE business sims in bulk and sell them for cheaper. So directly EE with 5g+ and stuff!
That I doubt! How'd they put 4 networks on 1 SIM?:
1 SIM, 4 Networks. Maximum Coverage
