Smart 5G Hub
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-02-2024 12:04 PM
A friend has just received this router and added an ATA for VOIP telephony. From what he tells me it is correctly setup for connection to the SIP server. However, calls cannot be made nor received.
Before I go further in trying to help him I'd like confirmation that EE do nothing to prevent VOIP telephony on this broadband service. For example, Three only allow data traffic and specifically block telephony. I hope EE don't do anything like this.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-02-2024 02:44 PM
Hi @Loades,
I'm not aware of anything that would prevent the use of VoIP services on our Smart 5G Hub but I'll check in with our device specialists and report back if they have any further information.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-02-2024 03:38 PM
Thanks. Would really appreciate what they have to say.
Malcolm
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-02-2024 10:23 AM
Hi @Loades,
Our device specialists have confirmed that we have customers who are successfully using VoIP services over our mobile network.
They'd recommend contacting the VoIP software provider for confirmation of compatibility of their service with mobile broadband routers.
Hope this helps.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-02-2024 10:27 AM
Thank you, James. Now I know that I'll make a visit to my friend in the knowledge that I should be able to make it work.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-02-2024 10:29 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-04-2024 01:07 PM
Hi, sorry to dig up this old thread but we are aboutto try getting an EE 5G router etc installed at our office, with an antenna. We are finding it very difficult to find a router that has 4 antenna ports that are required and also be compatible with VOIP by having static IP address.
A lot of people seem to be having trouble with VOIP because they are using routers that do not allow static IP.
Can anyone suggest a router they have used with 4 antenna ports and static IP??
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-04-2024 05:21 PM
Hi @AlliedEngineers,
Sorry, we don't offer static IP addresses on our mobile broadband service.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2024 08:57 AM
Hi James,
Just to clarify if I get a router and EE 5G sim, it will never work with a VOIP system (which requires static IP) ?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2024 10:49 AM
Yes, if your VoIP service requires a static IP (many don't), it wouldn't work with an EE mobile data connection.
- 75 inch android smart tv in TV
- Does Smart Hub Pro password require special character? in Broadband & Landline
- Ethernet connection from home hub to wife smart plus booster in Broadband & Landline
- Interpreting BSSIDs on the Smart Hub Pro and Smart WiFi Pro in Broadband & Landline
- EE Smart WIFI Plus SW30A - PoE? in Broadband & Landline
