on 17-05-2024 07:43 PM
I bought a Smart 4g hub, model D412C57, s/n C57ABL2497K2AO67 on AliExpress. But the admin password is not correct. I can't enter settings. How to get the admin password?
on 17-05-2024 07:50 PM
@igorr3001 : If the admin pwd on the label doesn't work do a factory reset by pressing a pin into the Reset pinhole for about 10 secs.
on 18-05-2024 08:06 AM
Thank you for your answer, but reset don't help. I have a problem to use phone. Why support don't send work password by email? Ussualy password admin works on other routers.
on 18-05-2024 09:00 AM
Return it to the seller.
on 18-05-2024 09:31 AM
Thank for advice, but i can't it. Seller don't answers.
18-05-2024 09:32 AM - edited 18-05-2024 09:33 AM
Then claim against the marketplace's buyer protection policy.
