20-01-2023 01:56 AM
I’ve lost my keep me card.
how do I reset the password for the mifi
20-01-2023 03:44 AM
@203182184 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
20-01-2023 01:55 AM
20-01-2023 03:44 AM
