on 28-02-2023 08:18 PM
I work at a school and am now unable to access our remote server since having a 4G EE hub.
it works if I hotspot off of my Vodafone phone so I know it’s only the EE hub causing the issue.
I have changed my child lock settings to adult already.
EE haven’t been able to help me over the phone but my IT team at work say it’s a known issue with EE security blocking remote access.
has anyone had this issue or can recommend a solution please?
thank you.
on 01-03-2023 08:12 AM
Hi @AndrewChristmas,
Is the remote server IPv6 ready or does it only allow IPv4 connections?
on 06-06-2023 06:31 PM
I have the exact same issue with my 5G router.
My schools direct access uses the following:
Any help would be gratefully received as I can't get any work done at home!
on 06-06-2023 07:02 PM
Hi @bethanlouise,
Has your school's IT support team been able to identify what is causing the issue?
on 06-06-2023 09:48 PM
No. They have looked into the laptop extensively at school and at home and they can’t see any issues. It works correctly when connected to any other provider apart from EE so it must be a problem on EE’s side. I rang yesterday and was on the phone for a very long time but didn’t get anywhere.
I have reset the router a few times and the laptop many times but nothing is working.
on 06-06-2023 09:50 PM
WhatsApp and Instagram also won’t work on our phones when connected to the WiFi.
on 07-06-2023 09:00 AM
on 07-06-2023 06:20 PM
Yes I have .
on 08-06-2023 08:12 AM
OK, thanks @bethanlouise
It sounds like you may need to speak to our technical support team so they can look into this for you.
