Re: How to top up 4GEE WIFI MINI
Torrymac
it is asking for a mobile number and I don't have a number as its a WIFI mini pay as you go dongle
@Torrymac : As they're mobile devices, all mobile routers have a SIM in them which has a mobile no.
To get its no. either:
  1. Go to http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi.
  2. Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then look under its System Settings for its MSISDN.
  3. Text NUMBER to 150 from it.
