Portable EE 4G MiFi WiFi Device - OCT 2023
TinkerTailor
A) Can anyone provide the model number + product code and full model identifier, for the latest/most-current 4G MiFi device I can purchase from EE?
B) What is the product support life of this current model? How can I find out?
(Given that such devices need the occasional patching/firmware-update, I think this is a reasonable question. I do not want to purchase if it will only be supported for another 6/12/24 months before support is pulled).
C) Who is the origional manufacturer & what is their model, that this EE variant is based off?
19 REPLIES 19
Christopher_G
Hi @TinkerTailor
I see you've been given some great product information. Here is the information that I've been able to find:
Description: 4G WIFI
Model: EE72e
EE part Number: 300030846
Our Technical Support team can support you with any faults you may have with the device and there's a 24 month warranty.
TinkerTailor
Got my new MiFi Device from the EE store today.
Put my wife's sim (Sim Only) in the device (40gb, utl, utl).
I am able to access the MIFI device's settings page (via wifi) from my iphone. I can access the device settings.
The devices "Connections/Network" tab, says it is connected to the EE network.
But when I try to browse the internet (through the mifi device) on my iphone -  it says there is no connection.
What do I need to do?
(There is 39GB left for the month ahead).
What am I doing wrong?
Leanne_T
Hi @TinkerTailor
Thanks for coming here.
Does the SIM connect to the internet in another device?
Have you restarted the router?
Okay, so I worked out that it's the VPN on my phone, that was causing the issue.
It's up and running now.
I need one final bit of support.
Its both Important & Urgent.
The MiFi device has arrived and is working.
I plan to unlock it (so that I have flexibility in the future).
I will be using it with an EE sim for the next year at least. But on occasion, if I am located somewhere where EE's signal happens to be weak, but another providers is stronger (e.g deep inside a hospital wing) I may need to temporarily use another network.
The MiFi device was not bought on contract. It was a Device-only purchase.
I need your answers to be precise and accurate please.
I will be undertaking actions that will be dependant upon your answer to this question:
If I get the Mifi Device Unlocked by EE (I'm assuming its locked at arrival) will it still receive security/firmware updates when they are released?
It's important to me, that my devices are fully patched with any security patches/firmware updates released by the manufacturer in a timely fashion.
I want my devices to be as secure as possible.
I would like to know (conclusively), that if I get EE to unlock the device - will it still receive security patches/firmware updates that can be installed successfully.
I'm very grateful for your continued support.
TinkerTailor
Christopher_G
Hi @TinkerTailor
Yes, the device will still continue to be supported for software updates, even when unlocked.
@TinkerTailor wrote:
I plan to unlock it
No need! Device sold nowadays are sold unlocked.
Okay,
@Christopher_G Thank you for your continued support thus far.
I am close to the of my line of enquiry.
The Mifi device I received is:
4G WIFI - Model: EE72e
A) Are they unlocked at the point of delivery?
B) How do I check?
C) Do they lock to the network of any sim, you first put in?
D) If yes, what is the correct unlock procedure?
E) Where can I get a breakdown of the technical specifications of this unit? (Upload/download speeds etc).
Many thanks & Happy New You to everyone that choose to help and contribute.
TinkerTailor
  1. Yes. All devices sold today are unlocked by Ofcom edict.
  2. Put another network's SIM in it & see if it works.
  3. No.
  4. N/a
  5. @Eddy2760 's post is probably as close as you can get.
StuWinstone
I have 2 of these 4G Wifi mini  router .
1 is working ok the other iam stuck with flashing RED/White light ?
the booklet  is vague here . Need some help  despite doing 10sec reset .
i can't access it via 192.168.1.1.
Be glad of any tips to fix this as am disable and housebound .
Product :4G Wifi
Model :EE72E
Manufacture :EE ltd
Description 4G Wifi , EE72EE
i got Mac code :
Made in CHINA !
@StuWinstone : Having done a Factory Reset what happens when you access it via http://192.168.1.1 ?
