Poor Internet signal
PaulW9
Bought a roaming Internet package. Currently in Chicago but all I'm offered is T mobile 2g which hardly works. How do I change to a better supplier for roaming over here
6 REPLIES 6
@PaulW9  Try doing a manual network search on your device.
Yes I've done that. Could well be this is the only signal available to me in Chicago.
James_B
EE Community Manager
Hi @PaulW9,
Was AT&T available when manually searching for a network?
Have you been able to test your connection in more than one location?
No only offer was T Mobile 2G.
Nothing else showed up. I do get a signal but limited performance. However I've answered this message using it 😅
Get Outlook for Android<>
James_B
Hi @PaulW9,
Have you been able to try in another location? It may just be that there is limited coverage where you are at the moment.
It's pretty much the same signal all over Chicago. Will be in Florida in a few days so I'll see what it's like there.
