PAYG Data only SIM not registering with My EE
Gemmerson
Hi , I bought an PAYG EE Data only Sim to use in a Netgear M1100 to produce a wifi signal in a motorhome. SIM works fine and wifi signal all ok, however going round in circles on the EE web site. Registered my details, log in, put in the Data Mobile number on the packaging to register and EE site just asks me to connect to the data sim and log in...... but I am already logged in. Any help much appreciated.
@Gemmerson : MyEE doesn't work for registering PAYG MBB devices or at least those with data SIMs. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your device but you just can't register it to MyEE.
  1. Use Fast Top Up online with a UK bank card. You don't need to login or register anything. All you need is your mobile no.
  2. Go to http://add-on.ee.co.uk/status from the device will tell you your usage & credit.
  3. Go to http://add-on.ee.co.uk/purchase from the device to buy add-ons.
Thanks very much for this. They really should fix the app for this, it just doesn't work, and sends you around in circles. No way to message them, and help says call 150 on a data only sim.  The status link is what I wanted, now book marked.
@Mstom : Thanks! You're welcome 🙂 ! Glad I could be of assistance & trust it is now sorted.
