13-10-2023 09:07 AM - edited 13-10-2023 09:18 AM
I thought my long running saga with EE signal in the HU18 1EL area was over. I had a 4G router an external aerial and was getting reliable and constant 4G speeds of around 60mbps. Then almost overnight they dropped to 2-4mbps with no improvement. The usual dialogue with EE and an admission they were doing work in the area and upgrading the 4G signal (note: no mention of 5G).
Then if by magic I noticed a 5G signal. Tests showed it was good but not excellent but in desperation (as I need a good connection for business use as well as personal streaming and landline is not an option) I forked out a few hundred quid on a decent 5G router.
Amazing results - 150mbps+ and stable. Well for 3 weeks.
But you've guessed the 5G signal as now gone and I'm back to the 2-4mbps 4G one.
I shall await the EE customer service response of 'well 4G is fine in your area and there are no faults, oh and 5G isnt available yet'.
Maybe I was hasty in buying a 5G router (but it was out of desperation, has anyone tried a Teams call when you are only getting 2-4mbps) but I also think it is very coincedental that the degredation of the 4G signal in the area (60mbbs down to 2-4mbps) coincided with the introduction of 5G.
And here I am paying £36pm for the privilege. And no I cant switch supplier as I have tested all the main ones and when EE4G was 60mbps it far exceeded the others (they were all 4-6mbps).
Rant over for now. It's good to get it off yer chest.
13-10-2023 09:41 AM
What a well-intentioned CS agent calls a signal upgrade could mean several things, but it's worth noting the multi-band nature of EE's 4G & 5G networks.
4G services are carried across 4 frequency bands (1, 3, 7 & 20) with multiple carrier configs in 3 of those.
5G services are carried across 5 frequency bands (N1, N28, N3, N7, N78) with a similar multi-carrier setup.
It's quite common for carrier or tech-adds to be done across both techs during the same works - but by no means necessary.
13-10-2023 12:00 PM
4G is B3 in this area and 5G N1 (although I have seen it at N28 as well).
Frustrating when 4G was stable and good for 2+ years then suddenly it goes and has never returned to former glories.
13-10-2023 12:04 PM
4G B3 is the standard deployment, although there's a couple of different carrier combinations. 5G N1 is re-farmed 3G, and is usually - but not always - alongside 4G-B1.
A new carrier addition will often mean optimisation activity for a short while.
