No port on my 5g mobile router?
Planterspunch
How do I connect hubs for my other devices? I used to just plug the security camera hub into my last router. Is buying a booster the way to go - and plug it into that?
Leanne_T
Hi there @Planterspunch
Thanks for coming here.
Have you found a way to connect hubs since you posted on the community?
If not, which router do you have and what devices are you trying to connect? This will help other users on the community offer suggestions 🙂
Hi - no still no wiser. I have the mobile 5g router with no ethernet port. I used to have my security camera hub plugged into the ethernet port on my last router, so not sure what I should do. It has been suggested that I get a booster with an ethernet port and just plug it into that. No idea if that would work?
Katie_J
Hi @Planterspunch
Our technical care team would be the best team to speak with regarding this.
I'd recommend giving us a call.
Katie 🙂
