on 19-02-2024 07:16 PM
How do I change my password on my mobile zte broadband. I have too many unwanted users do need to change the factory set password which cone with it
on 19-02-2024 07:23 PM
Login to your MBB router & on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
on 19-02-2024 08:55 PM
Thanks for your quick reply. How do I login to the mobile router? Thanks in advance
on 19-02-2024 10:53 PM
I wouldn't know that router unless you give me its EE name.
It should be written on a label somewhere on it or in a User's Guide. It's usually something like http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found on label or under the battery cover.
