NR5103E Modem mode?
RandomCarp
Hi all,
Is it possible to change the NR5103E (with the EE firmware V1.00(ACBJ.0)b14) to operate in a modem mode?
I use my own router and only need the NR5103E to provide internet access to the network.
RandomCarp
No.
Thanks for your swift response.
Can I disable the DNS server on the NR5103E, add it on to my network and then use the allocated IP address as the network DNS?
Mark
Are you mean DHCP? That would make more sense than DNS which is only used for domain lookup.
