28-09-2022 04:23 PM
My ability to send emails via domains (not Gmail etc) suddenly stopped. However from another site (and internet connection) they send fine. Having checked Outlook, router etc I can't find out why it suddenly stopped. The only difference appears to be my EE connection. Turning on my VPN however allows me to send these emails.
Any thoughts?,
Steve
28-09-2022 05:37 PM
Who is your email provider? What have you put as the Outgoing Server settings (all of them) in your Mail app, obscuring your name?
28-09-2022 06:30 PM
28-09-2022 06:32 PM
OK, then we won't bother to investigate them!
28-09-2022 06:35 PM
Thanks for coming here.
Is this happening when connected to a mobile WiFi device?
Which device are you using?
28-09-2022 06:46 PM
28-09-2022 06:58 PM
Thanks @kiwiositysteve
Did you use the same EE SIM card in the other router?
Which email provider are you using?
28-09-2022 07:06 PM
29-09-2022 08:18 AM
