Mobile 4g WiFi box
kevinweston75
I'm trying to change my password for my mobile WiFi device 4g, I access the http side of thing's but can't log in to change password with the password that's registered with the WiFi box so I believe I shall have to make a call to the ee company on Monday to ask for technical help
"Password that's registered with the WiFi box"? What's that? Registered where? I hope you don't mean your pwd for logging into your MyEE.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
