on 26-03-2024 01:31 PM
could someone please help I have had to reset my mini dongle iv had it for years now but I have forgot the WiFi password and don’t have the sticker on the back or the keep safe card I’m wondering if there is anything I could do as the admin thing isn’t working ether
thank you
on 26-03-2024 03:35 PM
Hi @Arrow21
Welcome to the community.
If you connect the router to a computer using the USB cable, are you able to access the hub manager?
28-03-2024 09:50 AM - edited 28-03-2024 10:12 AM
no i can not get on to the hub/admin sight
on 28-03-2024 10:48 AM
Hi @Arrow21,
Our Customer Care Team should be able to retrieve your password if you get in touch.
on 27-05-2024 07:12 PM
ry poor direction on here... no one is actually saying how to go about such things
on 28-05-2024 07:39 AM
Hi @Nev70
You need to access your hub manager to change the password settings. Please plug your router into a PC/Laptop and head to the hub manager:
http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover.
If you can't access it, you will need to speak with our technical support team.
