How do I register my mobile WiFi box
Paulabake-222
Hi
i brought a WiFi mobile box I would like to know how to register it and be able to check the data usage I’ve lost the original package so no instructions and I’m floundering trying to find out how TIA
7 REPLIES 7
Leanne_T
Hi @Paulabake-222
Thanks for coming here.
The SIM card should be registered for you, did you purchase this on pay monthly or pay as you go?
Leanne 🙂
Hi I brought the box with 120 g from Argos lost the packaging it works but I would like to see my usage and top up if need be
Leanne_T
Thanks @Paulabake-222
Please see our How do I top up a tablet or mobile WiFi device? Help page for details on adding credit.
To check data usage you can do this in your My EE or by going to add-on.ee.co.uk on a device connected to the WiFi router.
Thanks those links look good  but I think I need to register the device maybe ??
can you tell me how to do this thank you
Leanne_T
Hi @Paulabake-222
Do you need to register for a My EE account?
If so, please register here. This will send a text to the device to view this please see What texts will I get on my 4GEE WiFi device? Help page 🙂
In your online MyEE go to Menu > A/c Settings > Add an A/c & supply the mobile no. of your mobile router. If you don't know it, login to the router @ http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then look for MSIDN in its System Settings.
I went to that page as I tried to add the device to my account but it has sent a text to the device. The page link doesn't mention texts at all so completely useless. How can I retrieve a text from a wifi device please?
Thanks from Lorraine
