How do I add a sim that is used as a mobile internet hot spot?
katearnold
I don't use the phone.  I bought a sim to use in a wifi hot spot as our internet provider went bust.  I went to a store to get it.  They said it was all set up.  The then emailed me a link to access my bill but when I try and set up an account it says I have to get a code sent to my mobile number..  The sim card is in a router and routers don't take text messages.   I don't have a mobile phone.  How do I view/access my bill?  Basically - help!  I can't find a way to contact EE without phoning them.
Most mobile routers can receive texts & reply to them. Login to it & look for the SMS Section/Inbox.
