How do I find my remaining data on a pre loaded sim
Buster26
Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status.
Alternatively, if your mobile router does SMS, as most do, text AL to 150 from it.
AwaYeGo
I purchased a pre-paid  "Unlimited" EE Data only Sim through Scancom for my business. A few days ago my broadband connection was disconnected. I'm trying to find out why it was disconnected and when it will reconnect. Can you help?
Katie_J
Hello @AwaYeGo
Welcome to the EE Community.
Do you have a fixed home broadband connection or a mobile broadband connection?
Does your SIM still work that you have just purchased?
Katie
Hi Katie, mobile broadband, in a dlink router (tested and working with
another SIM). I have no connection from the SIM I purchased.. it's prepaid
and should be good until 08/01/2026.
Christopher_G
OK, thanks for clarifying, @AwaYeGo
I recommend speaking with our Mobile Care team so they can check your account and find out what's happened.
