High Packet loss
PARAGONIST
For the last week I experience random high packet loss when playing video games, usually it hapens for  2-3 seconds, but interval between spikes is variable, can be anything between 2 and 30min.
I`ve tried everything:
Windows update;
Network reset;
Network driver reinstall;
Reset router configuration;
Router update and downgrade;
I tested multiple games;
2 different PCs;
Multiple router devices - Mikrotik Chateau LTE18ax and 2 smartphones;
With ethernet and wifi;
2 different EE SIM cards.
I tested everything that I can from my end...
My speed and packet loss tests- examples
https://www.thinkbroadband.com/speedtest/1695856181381138855
https://packetlosstest.comhttps://packetlosstest.compacketloss command line pinging ee.co.ukpacketloss command line pinging ee.co.ukDuring gameplayDuring gameplay
10 REPLIES 10
James_B
EE Community Manager
Hi @PARAGONIST,
Does the network status checker report any problems in your area?
@James_B : That doesn't check fixed Home BB.
James_B
I believe @PARAGONIST is using an EE data SIM @XRaySpeX.
Ah, so he is.
Unfortunately there is no problems in the area.
I am using 2 Essential SIM cards, one is unlimited and the other one has a data cap, and both had packet loss in different devices.
James_B
Hi @PARAGONIST,
Please use the 'report a problem' option so our network team can take a look at this for you.
After submitting your report, you should receive an update with a day or two.
Problem has been reported... Time to wait I guess
DrumDrummy
I'm getting this too. Did it get solved?
