Factory reset of 4gee mini wifi router
Simon_B79
How do I factory reset my 4gee mini wifi mobile router?
@Simon_B79  You need to login to it as a admin user.     Under the battery cover you’ll see an IP address that you enter in to a web browser when connected to the device.  You’ll also see there is a admin password that you need to use.
Remove battery cover. Above middle of terminal end of battery is a recessed Reset (R) switch. Press down on it for about 5 secs. with a pin. It tells you that in the Getting Started Guide.
