Ee dongle abroad
Cromo
I purchased an Ee dongle from Currys b4 coming on holiday, how do i use it as I am struggling to get it to work. I do not have any other Ee devices, I just want to use the dongle as my data. Currys assistant said I just switch it on but that does not appear to be the case. I am in France. Thanks
Katie_J
Hi @Cromo.
Does your dongle have a SIM?
If yes, did you use this in the UK before travelling abroad?
Katie
Yes it’s got a sim and it worked on my non sim iPad in Curry’s when it was purchased with 120gb.
Ann
Sent from my iPad
Katie_J
Thanks for confirming @Cromo.
Is the SIM pay as you go?
To use your subscription pack abroad you will need to purchase a Roaming add-on.
Information on this add-on and pay as you go charges in the EU can be found HERE.
Katie
