EE5G NR5103 - Add a phone
JavaKing
The router has a SIM card and cellular light.
Is there any way to connect a phone to use the SIM?
if not, is there a way to add a phone - VoIP etc?
@JavaKing : Yes, either:
  • A mobile phone you connect by WiFi to the router.
  • For a landline phone you would need to sign up with a VoIP provider.
