on 23-08-2023 09:39 AM
I have recently aquired a NR5103e router (which is basically Three's version of the EE NR5103 with 'arguable' slightly better firmware).
Anyway it was a doddle to setup with my EE sim but I am after some feedback, either from NR5013e users or NR5103 users, as to 5g signal coverage.
The area I am testing the device in (LS26 8WJ) doesnt have a good status regarding 5g coverage. But if I stick the EE sim in my Google Pixel 6 Pro I get 5g coverage reported at the top of the phone (although I am suspicious of that) plus speeds of 20-40mbps on occasion. I say suspicious because some of my testing apps only show 4g+ LTE (Band 3) whilst others are stating 5g.
Anyway baring this in mind, when I put the EE sim in the router, I never get any bars showing for a 5G signal but 4g+ is full signal.
I have seen reports that many of the NR5103e router were shipped with a fault where they could never receive a 5G signal. I just wondered if, even in a marginal area where my phone shows 5g, I should be seeing some status within the router that there is a 5g signal even if it latches on to 4g+ all the time.
on 23-08-2023 11:46 AM
Hi @archercj
If your router is connecting to 5G, it should show a 5G indicator. Are you able to try it in an area with a stronger 5G coverage?
on 23-08-2023 12:24 PM
Not until the weekend Chris. I will give it a go then
on 23-08-2023 12:38 PM
