Does the EE 5G mobile broadband support WiFi6?
tim5686
Valued Contributor
Valued Contributor
I am looking into getting a mobile broadband device to save tethering all the time as I travel and it would be easier through this.
Does anyone know if the EE device supports wifi6? I've seen some elsewhere that support wifi 6, but I can't find out if the ee one does.
Thanks.
1 ACCEPTED SOLUTION
@tim5686  Link to amazon for routers that support AX.
Amazon.co.uk : hotspot router 5g
Northerner
Hi @tim5686
You understand that WiFi 6 is just the connection from your device to the router, it's somewhat irrelevant becase mobile broadband is reliant on the network connection the mobile network.
You can also buy mobile broadband routers separately to the Sims.
tim5686
Valued Contributor
Valued Contributor
Thanks. Yes I am aware.
What I'm asking is whether the ee device supports connecting my phone and
other devices via WiFi 6.
tim5686
Valued Contributor
Valued Contributor
Thank you @JimM11 . Really helpful. Having continued to do some research myself, I've decided to go for my own router from Amazon rather than getting the EE device.
Regards,
Tim
