on 04-03-2024 01:40 PM
Solved! Go to Solution.
on 04-03-2024 01:52 PM
Topping-up is just putting money as credit on it. Have you bought a data add-on with it?
Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top. What does it say, obscuring your mobile no.?
on 04-03-2024 02:01 PM
You sure you have a mobile BB router? You can't make calls from them.
