Channel conflict on 5GEE router
jstvj1
I'm trying to change the wifi channel on my 5GEE Router but they are all greyed out and auto is conflicting on 36. Can anyone advise please.
1 ACCEPTED SOLUTION
The mesh setting was ticked and that was why the channels were greyed out. I untickled it and was able to change to channel 40 which is not conflicting with other wifis nearby
Christopher_G
Hi @jstvj1
Welcome to the community.
What is the reason you're looking to change your band? Are you having problems with the WiFi connection?
Hi Chris,
Thanks for getting back to me but the problem has now been solved by my local EE shop.
Christopher_G
Ah, that's great, @jstvj1
Could you share with us what they did?
James_B
EE Community Manager
Thanks for the update, @jstvj1 🙂
