Change password for Wifi Mini
Marianne10
Hello, is someone able to tell me how to change my password for the wifi mini device? Thank you
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
Thats as much use as a chocolate fire guard
@jimmyclarke1 : You're just inviting everyone to help you!
jimmyclarke1
ok thank you
