Blocking my vpn
Wilky17
Can I get EE to stop blocking my vpn?
@Wilky17   EE don’t stop you from using a VPN and they don’t block them.
Then why do they work on Three sim but not withEE on same router. Technical support can't fix it. Grrrrr!
Hi. Have you as yet found a solution? I’m having same problem. VPN blocked on fibre but was working fine before I upgraded. My work It says it’s ee!!
Glenn1611
FWIW I have no problems using NordVPN over EE.
Good morning, I have been told by an EE caller they dont support VPN issues so I cancelled my contract. I need VPN for work so EE as a provider no good.
