09-11-2022 05:33 AM
Hi the town I work in recently has been upgraded to 5 G great news you would think. But speeds are now slower than when it had 4g coverage. I am pretty close to the mast I get full bars for signal and speed test gives download speeds typically around 20mps and same for upload. On 4g it was more like 50 for download
And if I go to a city with 5g download speeds are usually in the 100s or above. Why the difference
09-11-2022 09:22 AM
Hi @kcurrie65
Welcome to the community.
What does our coverage checker estimate the 5G coverage like in your postcode?
How recently was it upgraded?
09-11-2022 10:00 AM
So the coverage checker for this postcode says I will get great 4g coverage dosent say 5g is available but it is and Is over most of the town. I would guess its been 5g for 5 or 6 weeks now. A welcome upgrade thanks but curious as to why speeds are less than before as that seems backwards step
09-11-2022 10:14 AM
You could be just on the edge of coverage, @kcurrie65.
It's likely to improve as time goes by and will be updated on the coverage checker as it does.
