on 16-09-2023 04:03 PM
Hi all
I’ve just had my 4g wifi mini which says it has a 30m wifi range. I’ve tried using it on my phone and it doesn’t pick up the wifi after 5 metres. So I was wondering if there’s a way of increasing it’s power ?
cheers
on 16-09-2023 04:33 PM
@Craig203 : Have you set it to the 2.4GHz WiFi band? That has greater range than the default 5GHz band.
