4g miniwifi
Lfcfan
I purchased a mini router out of a little shop in Oswestry it came with no box or instructions on how to use but it has a slot for a SIM card so I purchased a sim topped it up and inserted it it’s showing there’s 4g but I can’t connect as I don’t have a password is there anything that can be done ?  Tia
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
