4g EE mini box keeps turning off
Sarluk
I’m having problems getting the 4g mini mobile broadband to stay on. I’m getting around 30 minutes but then it switches off even if it’s plugged in. Can anyone help?
15 REPLIES 15
Christopher_G
Hi @Sarluk
Welcome to the community.
Could you try resetting it using the button/pinhole on the side/back of the device please?
Are you actually using it during those 30 mins. Most of them will switch off to conserve the battery after a period of idleness.
hongprprn
I just got the 4g mini mobile broadband today. After the previous version I had broke down and I’m having the exact same problem with the 4g mini mobile broadband 🤦‍♀️!!!
Leanne_T
Hi @hongprprn
Thanks for coming here.
Is the WiFi device a replacement?
Have you tried another charger?
Leanne 🙂
Mine is the same but I don’t have a reset button anywhere I can see ?
@Dave4129 : It's under the battery cover.
Stressed1
Hi, did you ever resolve this problem? Mines doing the same
I’m having the same problem, any tips gratefully received
Jon_K
Former EE Employee
Hi @Stressed1
Did you follow the reset steps as suggested above?
Let us know if this helps at all.
Jon
