4Gee WIFI mini mobile router very slow at initial connection to web sites
nnl
My 4GEE WIFI mini router works quickly once a web site is loaded - but it often struggles to load a site, and sites will time out. Is this due to some DNS issue? I cannot use some of my devices as they just time out - especially where there is some form of additional handshake - is there anything that can be adjusted to improve this communication / timing out issue
@nnl : It's probably down to the DNS but you can't change it on the 4GEE WiFi Mini router.
Thanks - yes - I assume it's the DNS, - which is centered on the router - (not an address on the web) ... would it be worthwhile to preset the DNS to - say Google where possible? Not really touched the DNS previously, but it seems to be very slow with EE
What do you mean, "centred on the router"? The router will point at addys on the Web, hardcoded, that are the EE DNS.
If you could possibly change them you would switch the DNS in the router away from EE's ones to 1 of these public DNS pairs:
OpenDNS   :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Cloudflare DNS 1.1.1.1 & 1.0.0.1
