4GEE wifi mini adding device
Annie103
I'm hoping someone will be able to help me.
I am trying to add my 4GEE device to my account, but im getting stuck on the last part. I add in the number, it verifies its mobile broadband, but then it asks me to connect to the wifi then regsiter for the account to be activated, but im already connected, registered and logged in?
I've tried logging out, setting it up with a different account but it doesnt seem to be working. Do you know where im going wrong?
@Annie103 : MyEE doesn't work for registering PAYG MBB devices or at least those with data SIMs. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your device but you just can't register it to MyEE.
  1. Use Fast Top Up online with a UK bank card. You don't need to login or register anything. All you need is your mobile no.
  2. Go to http://add-on.ee.co.uk/status from the device will tell you your usage.
  3. Go to http://add-on.ee.co.uk/purchase from the device to buy add-ons.
These should still work.
